Thoughts/opinions on a 383 build
Old Jun 14, 2008 | 03:54 PM
Tony_B972's Avatar
Car: 86 IROC
Engine: 383 (in progress)
Transmission: tko 600
I know these are dumb questions but humor me pls, here's what i got so far forged crank/rods(5.7) afr 195 elimintors (68cc i think), miniram w/ direct port nitrous 150-200 shot in thoery, hydro roller cam dont have numbers yet, and srp pistons -16cc all run off a f.a.s.t efi system. Now my first question is about the c/r will that set up i think ill be at 9.6/1 which seems a little low so i was going to change the pistons and bump the c/r up but im getting mixed opinios about how high i can go and still run safly on pump gas. Im thinking of switching to a -5cc piston which would bring me to something like 10.6, is that too high for 93octane? Also a random one can/should i use a bigger oil pan?
Old Jun 14, 2008 | 03:59 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: Thoughts/opinions on a 383 build
C/R is good for pump gas, may have to add some 104+ octane boost depending on the timing used and definitely you want a bigger oil pan to have plenty in the oil pick-up on turns and hard launches.
Old Jun 14, 2008 | 04:08 PM
Tony_B972's Avatar
Car: 86 IROC
will one fit w/out mods on a 86 and does octane boost really work?
Old Jun 14, 2008 | 04:35 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
octane boost works in theory not in practice as it MIGHT raise your octane 1 true point from 93-94 type of deal not worth it... if it was detonating on 93 it will probably detonate on 94
Old Jun 14, 2008 | 09:11 PM
Tony_B972's Avatar
Car: 86 IROC
bet ur right
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Jorlain
Oct 8, 2015 01:57 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
