problem removing sending unit from tank
Old Jun 14, 2008 | 09:35 PM
eddie jr's Avatar
Well, i was just wondering how the heck you get the sending unit out of the tank of an FI car? I got the lock ring off but i can't get the whole sending unit out of the tank. The float arm points to one side and the strainer to the other, which makes it wider than the hole. The strainer can't be bent according to the instructions and it has to be marked for direction and there is no way of taking it off in the tank.
How the heck do you get the unit out? I tried putting a wire in and lifting the float arm up to poke that out first but it can't swing all the way to the top.
thanks.
Old Jun 15, 2008 | 10:29 AM
eddie jr's Avatar
Re: problem removing sending unit from tank
TTT
I have read many cases on TGO of people doing pumps but never any mention of how to get the unit out of the tank. Any help?
Old Jun 15, 2008 | 10:47 AM
kerplunk318's Avatar
you could reach into the tank and rotate/remove the strainer... but you should be able to just fold it up to get the unit out.
Old Jun 15, 2008 | 02:06 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
when i did mine i just had to play around with it until at slid out, the strainer i think rubbed on the edge of the hole of the tank as i took it out, but it doesnt matter because ur gonna replace that just remeber how it was positioned, u can bend the strainer to if u have to
Old Jun 16, 2008 | 09:13 AM
eddie jr's Avatar
ok, cool, thanks. Got it out. They are kind of stiff and metal so i wasn't sure if you could bend it or not without damaging it (and it recommended not to in the new pump info).
Unfortunately the new pump is not plug and play though (AC Delco), you have to cut and splice wires. What did you guys do, just solder and leave it bare like suggested in the instructions?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
3rdgenparts
Aug 8, 2015 07:09 PM
