car keeps dying, i need help!!!
Old Jun 18, 2008 | 02:01 PM
cam_man's Avatar
Heres the deal... my battery keeps getting drained so when I try to start my car I cant. I replaced the battery twice, replaced the alternator and it ran fine for a few days. Now it is doing it again. Could it be the starter, voltage regulator or cylinoid? Or could it be something else and what could it be?
Old Jun 18, 2008 | 07:06 PM
mouthforcombat's Avatar
Car: '86 Iroc Z
Re: car keeps dying, i need help!!!
If your alternator was recently replaced and is not defective and the battery is new and it still drains, you more than likely have a short somewhere in your wiring.
Be sure to check everything over on the alternator and make sure everything is hooked up correctly.
Old Jun 18, 2008 | 07:41 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
These cars have an underhood light with a tip up switch thats known for killing batteries. If yours is still there, disconnect it and see if thats whats killing the battery.
Old Jun 18, 2008 | 08:02 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Make sure you didnt leave the trunk light switch on.
I know it sounds basic, but I've done it before.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
