1969 CAMARO TIMING
1969 CAMARO TIMING
HEY WHAT UP I GUYS I NEED SOME HELP I HAVE A 1985 MONTE CARLO SS WITH A 1969 CAMARO 350 ENGINE IN IT. EVEN THOU THE CAR IS HEAVY AS HELL THE ENGINE ITSELF IS GREAT I HAVE PUT A WEIAND STEALTH INTAKE MANIFOLD, A MILD CAM,A BG 650 SPEED DEMON. THE TIMING WAS OFF SO A LITTLE SO I SET IT TWELVE. WITH THE SET UP I HAVE RIGHT NOW WHERE DO CAN I DEGREE THE TIMING TO GET THE MUST HORSEPOWER POSSIBLE.
Transmission: 4L80E/4L80E
12 BTDC w/o vacuum advance is "stock" setting.
Want power, set the total mechanical at 34-36 BTDC.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It's about setting the timing on a carb'd SBC. Close enough.
Linson
Aug 21, 2015 02:12 PM
