083 head on one side 193 on the other...
Old Jun 20, 2008 | 07:51 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
that's right. My engine with less than 18K has a wobbling crank (balancer and pulley replaced already) and today I found a new gem of information. The pass side head is a 193 and the driverside is a 083.
Beyond performance, how else am I screwed?
Old Jun 20, 2008 | 08:16 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 083 head on one side 193 on the other...
I doubt it actually would make a big difference... the 'specs' of each are basically the same. On a stockish engine, it probably wouldn't make a difference. I've seen lots of stuff with mismatched castings (mostly '70s stuff with various combinations of 882/993/624 castings) and they ran fine.
Old Jun 20, 2008 | 10:53 PM
IROCmenace's Avatar
Car: 1988 IROC
Cool, thanks for the reply. I feel a little better.
Old Jun 20, 2008 | 11:09 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Be aware that 193 heads are TBI truck "swirl port" heads, meaning they have swirl ramps in the intake ports that do wonders for low RPM torque and help mileage. However for even a mild performance application, for lack of a better word, they suck. That swirl ramp is quite a restriction.
083 heads are 87-92 camaro L98 heads. They don't have the swirl ramp and therefore flow better at higher RPM, but don't support the same off-idle grunt as the 193 heads.
Since third gen engine management systems only have one O2 sensor on the driver side, they rely heavily on the fact that both banks of cylinders are mechanically identical. I've never done any practical experimentation with this situation, but going on my gut, I highly doubt your engine is running optimally.
Old Jun 20, 2008 | 11:14 PM
IROCmenace's Avatar
Car: 1988 IROC
Yeah I am familiar with the castings. I went throug hthis with a replacement motor that I bought from a local parts store. At least both heads matched at 193 even though they were wrong.
I bought this car with this engine in it already. And yes it does not run optimally. I am not worried about that. I just need it to last. My main concern is the motor barfing parts. I have akid coming and can't afford another car or engine and I don't want to learn to rebuild one on my daily.
I really don't know why I like these cars anymore.
Old Jun 21, 2008 | 12:11 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
If it's just a driver I wouldn't worry about it. I'd try to avoid WOT though.
No clue how this would affect emissions if thats even a concern.
Old Jun 21, 2008 | 04:36 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
One side of hte engine is going ot have different volumetric efficiencies than the otherside. I can imagine that it would cause some pretty funky issues in normal running. I'd switch hte heads to match the 083. They're cheap and easy to find.
84z96L31vortec
Aug 20, 2017 12:16 AM
wruiz
Aug 11, 2015 02:59 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
anesthes
Aug 8, 2015 09:37 PM
