Which Flexplate???
Old Jun 23, 2008 | 08:12 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Which Flexplate???
I have a 1998 vortec 350 with lt1 hyperutectic pistons. my question is which flex plate do i need? i asked the guy who built it and im pretty sure he said all 1 pc rear main blocks use an external balance, but i looked on summit and it only shows internal balance flexplates for 1 pc rear mains.....
I really dont wanna grenade my new motor for something dumb like the wrong flex plate.. PLEASE HELP!
Old Jun 23, 2008 | 08:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need a 153-tooth, one-piece-rear-main-seal flexplate.
It will have a weight on it, but that doesn't make it "external balance". That weight takes the place of a built-in weight on every SBC crank that was external to the block from 1955 to 1985. If that weight on the outside of the block made all of those engines "external balance", then the 1-piece RMS engines are too, I suppose.
The factory used an unbalanced flexplate/flywheel and harmonic damper on the 3.75" stroke 400 SBC's, which were often referred to as "external balance". That, and the 377/383 4" bore, 3.75" stroke non-factory engines using a similar crank are the only true "external balance" engines - and guess what -they have that weight external to the block just like the shorter stroke SBC's (although, there are 1-piece rear main seal 3.75" stroke aftermarket cranks that also need the unbalanced or weighted damper and a differently weighted flexplate/flywheel).
Okay, the factory crate 3.80" stroke engine may also be "external balance" - I don't know off the top of my head.
We've been over this many, many times before, it just seems to keep coming up. Don't let words confuse the issue, Summit will list a "normal" 1-piece RMS flexplate as "internal balance". That's what you need, a "normal" 1-piece RMS flexplate.
Old Jun 23, 2008 | 08:46 PM
MaNiAk86's Avatar
Car: 1983 trans am
Re: Which Flexplate???
Would this one from JEGS be a good choice??
http://www.jegs.com/i/JEGS/555/60150/10002/-1/750886|10537
Old Jun 24, 2008 | 12:01 AM
five7kid's Avatar
555-60153
Old Jun 24, 2008 | 12:10 AM
MaNiAk86's Avatar
Car: 1983 trans am
thanks alot, buddy
Old Jun 24, 2008 | 12:25 AM
five7kid's Avatar
Some of the Summit descriptions have "Rear main seal: 1-piece", "Engine balance type: Internal", "Flexplate balance type: External". While that doesn't totally clear up the confusion, at least describing it that way, you'll know you don't need a weighted damper with a flexplate thus described.
There shouldn't be any 1-piece RMS flexplate without a weight is the point I'm trying to make.
Old Jun 24, 2008 | 12:28 AM
MaNiAk86's Avatar
Car: 1983 trans am
ok the damper is the large stock 8" so i should be good right?
Old Jun 24, 2008 | 09:31 AM
five7kid's Avatar
Should be. As long as it's neutrally balanced.
Old Oct 8, 2008 | 07:33 AM
sleeper383's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
Sorry to ask but what do you mean by RMS flexplate.
Old Oct 8, 2008 | 12:45 PM
five7kid's Avatar
"Rear Main Seal".
Old Oct 9, 2008 | 06:36 AM
sleeper383's Avatar
Engine: 5.0L
Thanks five7kid
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
