Engine not starting?
Old Jun 24, 2008 | 02:42 AM
19transamtpi86's Avatar
Car: 1986 Trans am-Firebird
Transmission: Stock
I have just changed out the plugs and wires on my 86 firebird-trans am with a 305 tpi. The car Ran befroe changing the plugs and wires. during changing the wires we notice one of them was barely connected and two of them were leanging against the exhauat manafold and some of the wires were mismatched so whoever did this tune up oviously didnt care to much. but the battery was dead and my father decided to jump start the car the car turned over and ran for about 5 seconds and then shut off. we sprayed ether into the inake and she kicked over, so we no there is a fuel problem could jump starting the car posssible shorted out something or blown a fuse?
Old Jun 24, 2008 | 08:19 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: Engine not starting?
if you didnt connect the cables properly you could have shorted something.
i would double check to make sure that you didnt mess up any plug wires in the process.
i would also check timing, there is a slight possibility that you could have messed that up in the process.
Old Jun 24, 2008 | 01:23 PM
Transmission: Stock
Found the problem this morning the the 5 wires that are on the fuel pump relay harness one of the wires was pulled out and somebody just shoved it back in runs fine now after we fixed it but thanks for the help
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
