Gasoline in oil?
Old Jun 24, 2008 | 04:16 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Gasoline in oil?
I finally got my 406 running and I know the carb needs to be tuned and the timing needs to be dialed in but I pulled the dipstick and smelled like gas. I also pulled the valve covers and the oil looked kinda milky. Its a brand new motor so I am hoping its just running too rich due to the timing being off. Any other ideas?
Old Jun 24, 2008 | 04:21 PM
fordspanker's Avatar
Car: 92 Camaro Vert, 91 RS
Engine: 355ci
Transmission: TKO 500
Axle/Gears: 10 Bolt 3.73 posi
Re: Gasoline in oil?
change the carb.
Old Jun 24, 2008 | 04:23 PM
Engine: 406sbc
Transmission: TH400
I was thinking that. The carb isnt the greatest but I was hoping to atleast get the car running. The headers heat up pretty quickly too so I think its also the timing.
Old Jun 24, 2008 | 04:30 PM
Engine: 355ci
I had a float stick in a edlebrock carb once and it filled my crankcase with gasoline, not saying the timing might be out, but if you are getting too much fuel in the combustion chamber it will make the headers glow
Old Jun 24, 2008 | 11:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Mechanical fuel pump?
New mechanical fuel pump?
Most likely the diaphragm is ruptured and leaking fuel into the oil.
"Milky" is usually water mixing with the oil. But, if it's a newly built engine, could be assembly lube.
Old Jun 25, 2008 | 08:53 AM
Engine: 406sbc
Transmission: TH400
Mixture was retardedly rich, plugs were dripping with gasoline. Getting it all tuned today. Man does this motor sound nice though.
Old Jun 25, 2008 | 07:18 PM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: BTO 700R4
Axle/Gears: 4th gen 3.73
Either bad mechanical fuel pump, stuck float or bad needle & seat or if you have an electric fuel pump then pressure is too high.
Old Jun 25, 2008 | 07:35 PM
Engine: 406sbc
Transmission: TH400
We pulled the Mech. pump and it smelled like gas like crazy. I'm going to do an oil change and try the new pump. The carb isnt leaking and the car is now timed. Doing a compression test tonight as well.
Old Jun 26, 2008 | 06:48 AM
Engine: 406sbc
Transmission: TH400
Compression test showed 120-125 on all cylinders so I'm guessing its not rings. I'll be doing a oil change and the new mech. pump today. After that its checking the intake gasket and ultimately the carb.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
meeklay812
Oct 1, 2015 03:46 PM
