BUCKS at low torque
Old Jun 26, 2008 | 01:13 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
BUCKS at low torque
A solution to the following issue (which pizzez me off) continues to elude us:
- Car bucks at low torque but the problem continues at higher rpm but is somewhat masked.
- Acts like its loading up or starving – no smoke
- Perfect at idle – touch the peddle & it whacks out
- Has power but not smooth power
- Odd odor at exhaust
Vehicle: 1988 IROC-Z, 5.0 tpi, 5 spd. The car sat in my garage +/- 4 years without any starts.
What’s been done
- Fuel tank drained & wiped.
- New: Fuel Pump, Fuel Filter, Air Filer, Plugs, MAF, CTS.
What’s been checked:
- Plug Wires, Cap, Rotar,
- Vacuum,
- TPS (changed it & it got worse so re-installed orig),
- Fuel Pressure within spec.
- No error codes
Any ideas or suggestions will be most appreciated
Old Jun 26, 2008 | 01:36 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Re: BUCKS at low torque
possibly could be the computer going?... just throwing it out there..
Old Jun 26, 2008 | 04:41 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
an EGR messing up can cause this, i would investivate it
Old Jun 26, 2008 | 05:50 PM
MTB333's Avatar
I had a similar problem. It turned a few of the injectors quite working.
Old Mar 20, 2009 | 01:44 PM
gatorcola's Avatar
Engine: LB9 5.0 tpi
I've this issue with my ride for over a year. After 4 mechanics failed to find the problem, I took her to a local Chevy dealer and they have diagnosed the problem. IT'S WHAT 89RS_82Z SAID IT WAS 9 MONTHS AGO. A bad EGR valve.
Dang, I wish you would open a shop over here. I'd be your loyal customer.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
