305 H.O. cam
Old Jun 26, 2008 | 09:32 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
305 H.O. cam
I've been thinking instead of rebuilding a 350 i was just going to put in a new cam. So i called up Crane Cams today and they said this is the biggest cam i can get on the stock heads.
http://www.jegs.com/i/Crane/270/114122/10002/-1
what do you guys think.
Old Jun 26, 2008 | 10:31 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 305 H.O. cam
well which stock heads?...and how stock are they? completely like havent touched anything? then i would say that is about as much lift as you would want to run.... i would still be checking my clearances on them pretty closely you never know what your going to find on a stock head...
Old Jun 26, 2008 | 10:59 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: 305 H.O. cam
well im preaty sure they are stock heads it suposively had a rebuild not sure what was done. what do you mean wich stock heads and i can find out.
Old Jun 26, 2008 | 11:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Casting numbers under the valve covers will tell what heads they are. If this is a completely stock, rebuilt-and-put-back-together-with-same-heads '84 305, the heads are 416's.
Stock valve springs are a big problem - you'll float them with any kind of "real" cam in it. With better springs, you can typically go to the .460-.480" lift range.
Old Jun 27, 2008 | 01:19 AM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: 305 H.O. cam
? do i have to remove heads to put in heavier springs.
Old Jun 27, 2008 | 06:15 AM
ncgator's Avatar
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
Re: 305 H.O. cam
No. You can get a compressor fitting that goes into the spark plug hole and the compressed air is supposed to keep the valve up while you change the valve stems/springs.
Old Jun 28, 2008 | 02:33 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 305 H.O. cam
With 20+ year old springs on those heads, you'll want to replace them with you install the cam. And if the timing chain is stock too, you'll want a new one of those. And the list of things you should change or replace while you're in there just grows. That's why I say a cam swap on a stock engine is one of the last things you should do.
Old Jun 28, 2008 | 08:19 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: 305 H.O. cam
get rid of those exsaust rotators also they limit the lift
that cam is alot like the rv cam
dont pay alot of money for that size of cam
alot of people are mislead by new cam tech-
Old Jun 29, 2008 | 04:28 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: 305 H.O. cam
That cam did well in a non HO carb 305 I had. I changed the springs and timing chain with regular replacement parts. It ran well with headers and an edelbrock intake. You could also run a slightly more aggressive cam if you wanted to.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
