How can you test a distributor?
Old Jun 28, 2008 | 06:01 PM
89jim's Avatar
Is there anyway to test a distributor? When I first put my car back together it ran fine and about a week in it started running like crap.It would backfire and miss. I changed plus and stuff but no good. So I took out the distributor (which was brand new and replaced) problems where gone and things where fine. well here I am about 1200 mile later and I have the same problem. I tried just changing the module in the distributor and there is no difference. Can I have another bad distributor already? Is there a way to test them? Should I buy another one and try it? Any advise ??
Old Jun 28, 2008 | 07:41 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: How can you test a distributor?
Are you sure your getting the distributor hold down clamp seated right and tight? Is the clamp up side down? Is the cap coming loose? I doubt the dist. is bad. Its probably something simple.
Old Jun 28, 2008 | 09:00 PM
89jim's Avatar
Yes I did check the basics.I even changed the cap to an accel cap with brass lugs. I changed the control module inside the cap too. The car ran fine and had alot of get up and go .Just like that it started back firing and running crapy. I pulled the plugs and changed them too. I checked the firing order and that seems fine. I am sure it is somthing minor but a pain to find.
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
L98GTA87
Oct 19, 2015 10:43 PM
camarohelp
Sep 22, 2015 03:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
