1983 firebird w/t 305 running 100 % , lost power driving now will not start ? WTFF ?
Old Jun 30, 2008 | 05:37 PM
n1446's Avatar
Car: 83 ' Pontiac Firebird
Engine: LG44BBl
car operating as normal , suddenly rpms die and i coast to a stop
battery is fine
engine turns over
no start ?
plenty of fuel
alternator is new
have no idea
is this distributor ?
plugs , plugs are fairly new < 5000 k
signal is lost it seems
Old Jul 1, 2008 | 04:05 AM
n1446's Avatar
Engine: LG44BBl
Re: 1983 firebird w/t 305 running 100 % , lost power driving now will not start ? WT
bump car is stranded
bump bump
Old Jul 1, 2008 | 08:14 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what about spark
Old Jul 1, 2008 | 08:37 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Check spark.
Did the tach freak out before it died?
If so, maybe an ignition module.
Old Jul 1, 2008 | 09:58 AM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Did you check the power to the distributor?
I had that fall out once and it did the same thing.
Old Jul 1, 2008 | 01:23 PM
n1446's Avatar
Engine: LG44BBl
i havnt looked at anything yet i changed the breather yesterday it s possible i knocked the power to the distributor
hopefully it is as simple as that
Old Jul 1, 2008 | 01:28 PM
Toehead's Avatar
Since you were working in the general area yesterday, I hope that's it.
Old Jul 1, 2008 | 01:30 PM
n1446's Avatar
Engine: LG44BBl
toehead the tac did not freak out it simply dropped to zero at 80 klm/hr
with no response from the engine afterward - i tried starting hours later and still nothing
Old Jul 1, 2008 | 01:46 PM
Toehead's Avatar
Probably not the ingition module then. They tend to get a little twitchy before they die.
It could be as simple as a loose connection at the distributor.
Old Jul 1, 2008 | 02:05 PM
n1446's Avatar
Engine: LG44BBl
o k , Thank You everyone
i m off to troubleshoot
n1446
Old Jul 2, 2008 | 01:21 AM
n1446's Avatar
Engine: LG44BBl
so i checked the distributor and all is o k
there is a small fuel drip on one fuel line , accounted for , sitll no difference
no fire
Old Jul 2, 2008 | 07:38 AM
jamon8's Avatar
Engine: 350 tpi
break it down
how did you diagnose the dissy
what is the pick up coil and the res on that
where did you take the ign mod
how did you test the coil
Old Jul 2, 2008 | 09:56 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
ignition module.
Old Jul 2, 2008 | 11:48 AM
n1446's Avatar
Engine: LG44BBl
i went to check the cables running to the distributor and everything is connected , i followed all the wires running off it and all are connected
i ve had this car since february and where things are is still relatively new to me i have no mannual
Old Jul 2, 2008 | 12:21 PM
Toehead's Avatar
I would get a voltmeter and make sure that the distributor is getting power.
Pull a plug and check for spark. If not, and you are getting power at the distributor, pull the ignition control module and have it tested at a parts house.
Old Jul 2, 2008 | 03:41 PM
n1446's Avatar
Engine: LG44BBl
there is no spark comming from the plug wires
pulled the plug this afternoon stuck a screwdriver inside it and near touched the frame , no spark in any case
this distributor has eight posts no post in the middle , there is a latch clip across the topside
looks like a fuse box cover in a way
it s possible to remove all eight plug wires from the distributor cap without removing the distributor itself remy /delco remy is the brand
Old Jul 2, 2008 | 04:10 PM
Toehead's Avatar
yes. That is a coil in cap distributor , which is exactly what it sounds like. Just remember where the wires go on the cap.
Old Jul 2, 2008 | 04:14 PM
n1446's Avatar
Engine: LG44BBl
great
again Thank you every one for the direction
N1446
83 Firbird aka _ Stank_BooTy
Old Jul 2, 2008 | 10:15 PM
n1446's Avatar
Engine: LG44BBl
Old Jul 3, 2008 | 02:58 PM
n1446's Avatar
Engine: LG44BBl
Re: 83 firebird se 305 no spark troubleshooting
pic # 1
took the coil to a local shop and it tested O k
pic # 2
now i m into the distributor
pic number 2 is distributor with cap off exposing the rotor
local shop directed me to the problem being -more likely- the pickup coil -than the module itself
i m not sure what to replace now , i have the ignition module on order for next week ?
how to test the pickup coil ?
Attached Thumbnails 1983 firebird w/t 305 running 100 % , lost power driving now will not start ?  WTFF ?-07-03-08_1536.jpg   1983 firebird w/t 305 running 100 % , lost power driving now will not start ?  WTFF ?-07-03-08_1648.jpg
Old Jul 4, 2008 | 12:14 AM
Engine: 355
By looking at your photos you need to pull the distributor out and rebuild it. Looks like rust on the pick up coil. The mechanical advance will probably need bushings and springs. Might be easer to buy a reman. unit and swap it out. Easy to do, mark the fire wall where the rotor is pointing and where the vacuum advance is pointing on the intake. Pull it out and put the new unit in where the old one was and let it rip.I would replace the cap, rotor button, and wires while I was there.
Old Jul 4, 2008 | 10:47 AM
jamon8's Avatar
Engine: 350 tpi
they are like 80 bucks to your door off ebay
make sure they sell alot of them and they have over a 98% with over 1000 items sold
Old Jul 4, 2008 | 11:50 PM
n1446's Avatar
Engine: LG44BBl
ok what are the chances i buy distributor , replace it and still have no spark is this an ignitor problem then ?
ignitor or distributor first ?
Old Jul 6, 2008 | 12:31 PM
Engine: 355
None, because everything is contained in the distributor except the coil and you had it checked. Ingition module is in the didtributor. bolted to the floor plate in the back.
Old Jul 7, 2008 | 07:51 PM
n1446's Avatar
Engine: LG44BBl
ok have a distributor on the way
Thanks 4 sharing - tryin to keep the bird afloat
N1446
Charlottetown
Old Jul 15, 2008 | 11:02 PM
n1446's Avatar
Engine: LG44BBl
o Kay
First of all Thank U every 1 for your help
i picked a distributor from an 86 trans am and installed it tonight
the difference between the two is astonishing and i m am in shock at the moment
FTR
83 305 firebird se distributor interchanged with 86 TransAm 305 distributor
Makes rediculous difference
revs inprove 15 % -25 %
Lights both rear tires in dry weather
serious acceleration from StoP
1 happy teenage boy
lives in me
N1446
jhawkeye
May 25, 2022 06:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
justin57
Aug 20, 2015 07:05 PM
MENINBLK
Aug 5, 2015 11:58 PM
