car won't start
Old Jun 30, 2008 | 08:57 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
car won't start
after an hsr swap car won't start, car is ann 88 iroc wich had tpi, now has an hsr swap but original 88 tpi memcal. not sure if this is a dumb question but should the car @ least start i know i must disable the 9th injector and egr but will the original prom keep the car from starting, please help
Old Jul 1, 2008 | 08:58 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: car won't start
what?
slow down and explain
someone will slow down and help you if you slow down and explain the sitchy
Old Jul 1, 2008 | 10:29 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: car won't start
If all you did was swap the intake, then no. I'm not sure how the cold start injector can affect the starting on the older versions. What's the car doing? Is it cranking over and not firing or is it doing nothing?
Old Jul 2, 2008 | 05:11 PM
godreject's Avatar
Re: car won't start
car is just cranking over but not firing up, im unsure what could be the problem, i was told to mess with the timing which im yet to do, the car has sat for over a year now,
Old Jul 3, 2008 | 10:38 AM
jamon8's Avatar
Engine: 350 tpi
Re: car won't start
got fuel or spark
check there first
Old Jul 3, 2008 | 09:06 PM
godreject's Avatar
Re: car won't start
turns ou tit was my fuel i had about 20 pounds of pressure on start up, come to find out when i bought my hsr it supposibly came with 30 pound injectors, i replaced those with my stock 22's off my old tpi system and it turned on, has a very rough idle but @ least it runs thats a start, thanks 4 the input one problem down many still to go
Old Jul 4, 2008 | 10:21 AM
jamon8's Avatar
Engine: 350 tpi
Re: car won't start
no no no
when you checked the fuel preasure you should have gotten over 40 psi not pounds
its your fuel pump or you fuel preasure regulator
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
