Need to kick this around w/u guys-
Old Jul 1, 2008 | 07:18 AM
AMigs87IROCz's Avatar
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
Alright-
My 350...on the dyno makes, to the wheels 307hp and 347tq. When im on the road, putting the car under a load(take off, or anytime when engine is pulling around 3750-4000) the oil pressure dropps slightly. I have the stock oil pressure gauge, which has been proven effective and reading. Normally I teater around 60psi. When it dropps it will go down to 30psi, then when I let off the throttle, it goes right back to 60psi.
--Now I know this isn't normal.....I'm of course thinking the worst(cracked block/oil pump)...but I am not for sure.....ANY IDEAS GUYS??
Old Jul 1, 2008 | 08:09 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Need to kick this around w/u guys-
bypass valve spring
Old Jul 1, 2008 | 12:11 PM
Car: 1987 Iroc-z
...?? as in my heads??
Old Jul 1, 2008 | 09:55 PM
jamon8's Avatar
Engine: 350 tpi
oil filter bypass
sorry its in oil filter adapter
shot in the dark
wait, every time a diagnosis that is given for free over the internet without seeing and hearing the problem is a shot in the dark
junior419
Apr 7, 2025 11:35 AM
L0tuS
Oct 4, 2015 08:07 AM
Giocio
Oct 1, 2015 12:20 PM
mcbitchman
Sep 29, 2015 12:32 AM
tattmann
Sep 27, 2015 05:20 PM
