slow response to the wheels
Old Jul 3, 2008 | 04:52 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
after i swapped rear ends (from 3.08 to 3.45) i noticed that sometimes when i try to accelerate my rpms jump up high but i barely feel any torque at all, is this robbing me more of power? is my 305 no match for the gears? im kinda confused and wondering where its going because it sure doesnt feel like its going to the pavement
anyone experience this after a swap? or know where it could be going maybe?
Old Jul 3, 2008 | 09:18 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: slow response to the wheels
I was gonna say that it sounds like the torque converter slipping but you've got a 5 spd... ? If anything higher gears make it easier for less powerful motors to accelerate.
Old Jul 3, 2008 | 09:20 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
sounds like your clutch might be slipping thought... first time driving a stick? when was the last time it was replaced?
Old Jul 3, 2008 | 10:48 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
i doubt it, it pretty much happened right after i swapped. ive been driving the car for about 3 years now. i forgot to mention this though when i swapped the rear ends, i only connected two bolts and one bracket thing, theres supposed to be 2 you know the ones that cover the u joint i think its called. well 2 of the 4 bolts broke off so just one bracket. but could that really make a differ?
as far as the clutch ha, prolly never everything was stock. you think the clutch would do that?
Old Jul 3, 2008 | 11:45 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I wouldn't drive it like that, unless you want to lose your driveshaft
Old Jul 4, 2008 | 12:39 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
right on, i understand but that thing isnt going anywhere it seated in there nice and tight. i mean, that is what the torque arm is for, to keep the diff in place. BUT i know its not good but how the frack am i supposed to connect that bracket? i thought about just getting it welded slightly for support i mean hey, safety first right?
Old Jul 4, 2008 | 01:16 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
drill out the bolts and re tap the holes, or take the yoke off your old rearend and put it on the new one.
Old Jul 4, 2008 | 01:32 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Pinion yoke
yours probably looks a little different
Old Jul 4, 2008 | 07:22 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
+1000 driveshafts flying off are not a good thing.
Old Jul 4, 2008 | 06:26 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
hmm well i tired that i took the bolt off my old one and tired to yank the yoke off but no go so i though it was connected to the whole ring n pinion. dam that sucks, i think im just going to take it in to get yokes swapped and get that thing in there the right way. but is that true? just take that huge bolt off and the yoke slides right off? if so i feel retarded
Old Jul 4, 2008 | 08:53 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yes thats how they come off. Sometimes they have locktite or something on them and are a little difficult to get off, I use a universal harmonic balancer puller in those cases. Before you go pulling it off and bolting it on do you know how to set pinion preload? If you are just swapping it you could probably get away with just marking it and counting the threads.. also do youself a favor and don't drive the car until you fix that, that's very dangerous and asking for trouble..
scottmoyer
Sep 7, 2015 07:06 PM
Stryker412
Sep 7, 2015 09:11 AM
84 TA NV
Sep 6, 2015 08:02 PM
rsrookie
Sep 5, 2015 07:08 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
