Fuel pump...
Old Jul 5, 2008 | 12:39 PM
trillatl's Avatar
Fuel pump...
so my 82 z28 has been sitting for over 8 years while i was in Atlanta. all i would like to know is how hard is it to change the fuel pump on it and what else would cause fuel to not go through my injectors?
Old Jul 5, 2008 | 01:02 PM
trillatl's Avatar
Re: Fuel pump...
damn i cant get any help lol???
Old Jul 5, 2008 | 05:17 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Fuel pump...
First off are you positive the pump is bad? What is your fuel pressure reading while cranking? Does the pump make any noise when you first turn the key? Are the injectors receiving a pulse? Have you put a noid light on any of em while cranking? The first thing I'd personally do is syphon that tank out, I doubt 8 year old gas is still combustable. Have you tried starting it with starting fluid? If you do end up needing to change the pump it can be a bit of a PITA, you have to drop the rear low enough to get the tank out from above it.
Old Jul 5, 2008 | 11:39 PM
trillatl's Avatar
Re: Fuel pump...
fuel pump makes no noise at all i hear nothing when i turn the key... i will try all of those other things in the morning thanks guys...
Old Jul 6, 2008 | 12:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel pump...
This is a crossfire car?
Old Jul 6, 2008 | 11:44 AM
trillatl's Avatar
Re: Fuel pump...
yes its a crossfire...
Old Jul 6, 2008 | 12:42 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Fuel pump...
check to see if you are getting power to the pump. might be the fuel pump relay.
Old Jul 6, 2008 | 02:44 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Fuel pump...
check the relay, also make sure that all your electrical connections under the hood are connected. i had to swap out my fuel pump because i didnt hear it when i turned my key, it started with starting fluid and the relay was fine, then after i put in the new pump, it still didnt start, then i noticed this black wire with a green connector that was disconnected, i connected it, boom i had fuel. biggest waste of 200 dollars on a fuel pump.
by the way anyone wanna buy a fuel pump? lol
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
