what type of adhesive?
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
What do you use to stick the rubber strips down on a fuel tank any type of adhesive in particular? Thanks
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: what type of adhesive?
weatherstrip adhesive would do the trick.
RTV would probably work fine too. Just make sure the tank is super duper clean. I'd scrub it with scotchbrite first...
MrPackstin
Oct 25, 2017 08:09 PM
