tpi idle issues
Old Jul 9, 2008 | 06:47 AM
kymmie 89's Avatar
Car: 1989 iroc z 5.7 tpi
tpi idle issues
89 350 tpi auto 100k 120 130 psi all cylnders new dist, plugs, wires
car starts and runs good until it drops to low idle it surges 500 to 750
on a regular cycle and you can hear an intermittent miss or studder, i figured the miss was in the burned up plug wires, but no change with the new ones
thanks for any help
Old Jul 9, 2008 | 11:33 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: tpi idle issues
You should post this also on the TPI board.
Check your TPS and IAC.
Old Jul 9, 2008 | 12:01 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Re: tpi idle issues
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
