Idle Speed Question
Old Jul 9, 2008 | 03:31 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Idle Speed Question
What should I set my idle speed to on my car? 1985 Camaro 305 Tuned Port Injection, automatic, has a cam in it 260/260 duration .444.444 lift(dont know if that would make a difference or not).
Old Jul 10, 2008 | 07:49 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Idle Speed Question
Also, I just read that the set timing connector must be unplugged while doing this adjustment. Is that really necessary?
Old Jul 10, 2008 | 12:27 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
any ideas?
Old Jul 10, 2008 | 04:57 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
The stock idle RPM is 500 (without IAC connected and Hot engine)
You can try setting it to 550rpm and then connect the IAC again and test for proper idle operation.
Thirdgen manual : https://www.thirdgen.org/tpimod2
Iroczone manual : http://www.iroczone.com/techartcleaniac.html
Let me now how that turns out for you. (its best to log with TTS Datamaster or an real RPM tool, its hard to see exact on the rpm gauge inside the car. Im using Datamaster when setting idle rpm..)
Old Jul 10, 2008 | 10:27 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks, I used that page and set my idle, it has a slight stalling problems sometimes though. Should I turn the idle up more with it having a cam in it or is that not necessary?
Old Jul 11, 2008 | 07:52 AM
Theking's Avatar
Car: 1989 IROC-Z
You could try 575 and see how that turn out for you. I wouldnt go much above 575 (without IAC) that can cause high idle, wich isnt nice. idle around ~750 warm engine got nice sound
Old Jul 11, 2008 | 09:25 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I just redid the idle. Car now idles in park at about 1000 and idles in drive about 750 according to the tach in cluster(only tach I had available).
Old Jul 11, 2008 | 12:44 PM
Theking's Avatar
Car: 1989 IROC-Z
well 1000rpm is to high it should try setting it lower.. try getting closer to 750/775 with IAC connected and idle..
Old Jul 11, 2008 | 03:24 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Now its idling at about 850 in park and about 700 in drive.
Old Jul 11, 2008 | 04:06 PM
Theking's Avatar
Car: 1989 IROC-Z
Still little too high I think. try lowering it little more.
How does it run with that idle ?
Old Jul 11, 2008 | 04:31 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
At this idle setting it seems to be alright. Im having problems with my car being very sluggish/slow (cant figure out that problem) though and the higher I had the idle the less likely it was to stall. Sometimes when I really get on the gas it will stall and other times when I go from driving to making a quick stop it will also stall.
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
perZ
Aug 15, 2015 01:17 PM
