What tools to use to change motor mounts?
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
My 83 T/A has a broken motor mount so I am out there trying to get those bolts out of the crossmember and you just can't get to them that easily.
What combination of sockets, extensions and swivels did you use to change them????
Transmission: 4L80E/4L80E
15mm swivel socket, 10" extension, 3/8" ratchet, 15mm combo wrench, and a 17 year-old.
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: What tools to use to change motor mounts?
i had a lot of luck with an extension with a universal and a 15mm socket. some still have to be gotten with a wrench. I dont know if you saw it but there is a hole in the K member to the rear by the strut and spring, its easier to get a wrench on the bolts from here. When you put the bolts back it put some rtv or something on the bolt and stick the washer on it, saves a lot of headaches.
383backinblack
Aug 15, 2015 06:36 PM
NBrehm
Aug 5, 2015 07:57 PM
