sound chip of the new motor and xe274
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
350 with 9.75 comp, trick flow heads, 750dp, perform rpm intake, xe274 using 1.5 rr , 1 5/8 longtube hedders. http://videos.streetfire.net/video/n...tor_171260.htm
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: sound chip of the new motor and xe274
I like how he romps the throttle and it moves the camera.
You probably need to advance the timing on it. It will need to be much earlier timing than stock.
its set at 36 deg all in at 2500
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
whats the idle timing set to? i wish i could get my car to idle smoothly at 800 but i think its not gonna happen. It needs 900 but i havent finished the tune. I got like 26 degrees at idle
Engine: 350 4BBL
Stock timing is like 6° base and 36° all in at 2500.
That cam will probably like something around 18° base and 38° all in at 3000.
(that is, unless you like the "about-to-die" exhaust sound)
Orr89, is your cam bigger than a 280?
Car: 89 Iroc-z
Transmission: TH400
its 286/306 advertised.. 230/245 at .050". i have run 23 degrees and it idled on it but was searchin alot so i bumped it up and it liked it abit better. I have other issues causing the searching so if i figure all that out, i'll go play with timing
Engine: 350 4BBL
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Good luck with those XE grinds... I had 2 of them XE274's fail on me
Car: 89 Iroc-z
Transmission: TH400
Intex1982, did that car hit 12's yet?
is it running better than before?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I have almost exactly the same combo as you do (200cc World heads, and different headers though) and mine seems very happy with about 16* mechanical at idle, and it idles even better with the vacuum advance hooked up as well (its in the 20's with it hooked up).
Engine: 350 4BBL
just got this motor runing friday taking it to track next friday. but it never hit 12 before my old car did with my old motor. i had to idle it up to 1000 its loading up bad.
well i break it in the way comp cam said to.
Engine: 350 4BBL
I know, I'm just stating the obvious...
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Sounds awesome. Can I take a guess and say 40 series muffler[s]?
yea 40's
Car: 89 Iroc-z
Transmission: TH400
problem with flat tappets is that modern oils are featuring less and less zinc and phosphorous i believe which help lubricate parts better. Since most cars are now rollers or overhead cam setups with roller parts, they can get away with less zince and such.
now is the time to convert to rollers.
NBrehm
Aug 25, 2015 11:49 PM
? Hopefully he broke it in right. At least he didn't start off with 1.6 rockers...
