oil leak related to wrong pcv?
Old Jul 14, 2008 | 05:09 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
a couple months back i installed a 350 from a 84 vette into my 85 LB9 iroc and carried all my tpi stuff over. since the swap iv had a decent size oil leak at 2500 and up rpm.changed the oilpan gasket twice and still a leak, i used the 1-pc fel-pro gasket. i read that a bad or wrong pvc valve would leave pressure in the crank case? so i went from my origional pcv valve off my LB9, and installed the valve that came with the 350. seems to almost cure my leak? the smog pump bolt is in place and sealed,and both pcvs seem to be in good shape. does this make sence?
Old Jul 14, 2008 | 06:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: oil leak related to wrong pcv?
Definately, an improper PCV setup can cause a slight pressure to build up in the block which can push oil out any of the gaskets or the dipstick.
mddaniel
Sep 8, 2015 05:16 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
drathaar907
Aug 6, 2015 04:20 PM
