Engine oiling question?
Old Jul 15, 2008 | 12:52 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Tonight when I went to adjust the valve lash I noticed one rocker had pretty much a river of oil flowing down it. I assume this is not normal? It was the number 2 intake. Also when setting the valve lash on it it did not seem to get as tight as the rest even though I set it the same way. What would cause this? I just redid the top of the motor with a cam, new heads, lifters, pushrods, crane gold 1.5's, headers, etc.
The engine has a tick that I can't figure out. I have adjusted the rockers twice. I am thinking its either a header leak or a rod
It is most noticable between 1300rpm and 2500rpm and gives me knock counts. It is consistent with engine rpms also.
Anyway if you can make sense of all this..any help would be appreciated.
Old Jul 15, 2008 | 12:54 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine oiling question?
One lifter? Unless you took the intake off, you couldn't have been able to see a lifter. Do you mean a rocker?
Old Jul 15, 2008 | 02:40 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
yes it was a rocker, don't think the car would run to well without the intake hehe.
Old Jul 15, 2008 | 11:24 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Anybody?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
