Which PCV valve for a 355ci
Old Jul 15, 2008 | 10:50 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Can i keep using the stock pcv valve that came off my 305 or do I need a different one for my new 355?
Old Jul 15, 2008 | 10:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Which PCV valve for a 355ci
The stock one is fine.
Old Jul 15, 2008 | 12:18 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
How do you know? How does one select the proper pcv for a performance engine?
Old Jul 15, 2008 | 01:25 PM
MN246's Avatar
Car: 84 Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.73/Strange 12 bolt
I would suspect the specs of the pcv valve have more to do with the volume of the interior of the crankcase and less about the performance of the engine.
Old Jul 15, 2008 | 03:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
More to do with how much idle air is expected to bypass the throttle through the PCV. For a performance engine, it doesn't matter.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
