higher viscosity needed for extreme summer heat??
Old Jul 16, 2008 | 03:35 PM
89Formula_350's Avatar
Car: 89 Formula 350 Firebird
Engine: L98 350 TPI
Transmission: stock auto
I live in El Paso, TX, where the temperatures can peak into the low 100's during summer. I have heard that running 20w-50 might be a good idea for that one oil change during the 3 hottest summer months because the engine needs a higher viscosity oil to handle the extreme air temperature. I run 10w-30 during the rest of the year. Is the 20w-50 over-kill??
Old Jul 16, 2008 | 03:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: higher viscosity needed for extreme summer heat??
Oil is heated by the engine, not the atmosphere. Your 260+ degree oil temperature doesn't change much just because the ambient air temperature has gone from 70 to 90 degrees.
Old Jul 16, 2008 | 04:24 PM
Engine: L98 350 TPI
OK, that is kind of what I was thinking ... so I guess I have fallen victim to hearing another truth-less myth. Thanks for the answer. I searched this forum, but couldn't find this topic covered. I hope this helps others who are living in the southwest.
Old Jul 16, 2008 | 05:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
We need to make this post a sticky or something. This is a very common misconception. People seem to think that if you're standing by your car sweating, all of a sudden your engine is running hotter. Your engine barely notices the difference if it's 70* or 100*F out there, it's still going to be much hotter in the coolant/oil/combustion chamber areas.
Apeiron said it well, and i'll probably be cut/pasting his quote there in the future....
Old Jul 16, 2008 | 06:07 PM
Engine: L98 350 TPI
I know I am passing this information on to the guy that told me about this misconception in the first place ... not to mention the people that ask me this question all the time too.
Old Mar 9, 2010 | 08:59 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
hmmm... I've been running Mobil 1 20-50 since '03... guess next oil change I'll drop down to Mobil 1 EP 10-30....
Old Mar 14, 2010 | 09:45 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I believe that oil viscosity matters when it is very cold. It gets too thick at sub zero temps at start up. Once it is warm, the oil wouldn't know the difference between 0 and 100 degrees out side temp.
Old Mar 14, 2010 | 10:04 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Thick oil isn't formulated to deal with extreme heat anymore than regular 30 weight. If you're actually worried about your oil getting too thin because of heat, install an oil cooler. Using thick oil to deal with this is like sticking gum in a leaking dam.
You should go down to 5W-30, it'll be better for you engine when it's cold and the same once warm.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
