Crank twisted?
Old Jul 17, 2008 | 06:07 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Crank twisted?
Last night i blew a radiator hose and noticed that my crank seemed to wobble as the pully turned...is this a sign of twisted or bent crank?...the engine doesnt seem to make any out of the ordinary noise or vibration...should i be worried?....its maybe moving 1/8th to 1/4 inch
Old Jul 17, 2008 | 06:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Crank twisted?
this is when the motor is running or are you turning it by hand? i would doubt the crank is bent.
Old Jul 17, 2008 | 07:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Crank twisted?
No, I highly doubt it's a crank problem. You'd think it's armageddon if it was.
Sounds like your balancer or pulleys are loose.
Old Jul 17, 2008 | 08:25 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: Crank twisted?
its when the motor is idling at 800 rpms...it moves but not a lot...i would think i would know when i change my oil this weekend..i figure there will be a lot of metal shavings...
what motor oil weight should i run?...im going synthetic but dont know what weight i was thinking like 5w-30 or 5w-20
Old Jul 17, 2008 | 08:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Crank twisted?
10w-30 is fine.
Old Jul 17, 2008 | 09:10 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: Crank twisted?
cool thanks for everything!
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
aaron7
Sep 30, 2015 09:15 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
