Dropping the oil pan?
Old Jul 17, 2008 | 08:32 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
I did a search and came up with nothing. Is it possible to drop the oil pan on my 355 enough to put in a new gasket without jacking up the motor. Are there any bolts i absolutely will not be able to get to even with the proper extensions and swivels/swivel sockets?
Old Jul 18, 2008 | 10:26 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Dropping the oil pan?
no you must jack the motor
these are not trucks
you should be able to get to all the bolts
Old Jul 18, 2008 | 02:00 PM
stroker_SS's Avatar
Engine: 355
Are you sure, i don't need to pull the pan out just lower it enough to pull out the old gaskets and install new ones, and if i do need to jack up the motor is it safe to do that by jacking on the harmonic damper?
Old Jul 18, 2008 | 02:16 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
no do not jack up by the dampener u need to lift the motor with a "cherry picker" engine hoist... the dampener can and will snap off the snout of the crank it happens alot. u will have to lift it cause the pan sits soooooooo close to the k member....
Old Jul 18, 2008 | 08:32 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
That's odd. My search turned up this THREAD. It's even got the hint on where to spot the crank...
Old Jul 18, 2008 | 09:03 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
the crank will be fine, lifting the engine. but if you start to lift the car by the balancer, its toast!
Old Jul 20, 2008 | 01:19 PM
jamon8's Avatar
Engine: 350 tpi
what about cleaning the mating surfaces and the junk in the pan
its in there
I guess I just get lucky jacking the crank
or is it the fact that I use a 2x4 vertically and it will break before the crank
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
