what's the difference between an hitachi-style starter and a gear reduction starter?
Old Jul 19, 2008 | 06:48 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
what are the good and BAD things to watch for on these starters?
Only used OEM before, but ready to upgrade starter to something reliable without heat-soak problems.
My car's 100% stock (305 lg4, 700r4, & exhaust).
Old Jul 19, 2008 | 08:26 PM
EvilCartman's Avatar
Car: '82 Z28
Re: what's the difference between an hitachi-style starter and a gear reduction start
I've had both types... Hitachi starter = very small package, lots of room around the header. One I got came with nice hardware. It's currently what I'm running on the car.
Gear reduction = bigger package, had to clearance header slightly for it to fit even after trying to clock it in different positions.
Old Jul 19, 2008 | 08:41 PM
scooter500's Avatar
Car: 87 Camaro Z-28
how does the gear reduction starter compare in size to a stock starter?
Old Jul 20, 2008 | 02:40 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Both styles are smaller than stock IIRC.
Old Jul 20, 2008 | 08:49 PM
scooter500's Avatar
Car: 87 Camaro Z-28
ok, thanks guys, hitachi = smallest & gear reduction = smaller than oem starter & hitachi probably best for headers
is one of these starter designs generally more trouble-free than the other or is it hard to say?
my setup/use will be for a 100% stock exhaust & engine... guess it'll be my first customization
Old Jul 21, 2008 | 05:51 PM
scooter500's Avatar
Car: 87 Camaro Z-28
bump... any opinions on which is a more reliable starter design?
Old Jul 21, 2008 | 06:46 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
well if its ur first "customization" then i would go with the hitachi since you will probably get headers down the road since most ppl do.
Old Jul 21, 2008 | 10:08 PM
scooter500's Avatar
Car: 87 Camaro Z-28
hey guys, yes, if buying new looks like Hitachi is the way to go. Learned that gear reduction was developed by Rolls Royce, then Chrysler. Hitachi continued starter motor improvements & Hitachi design is smaller than a gear reduction start motor. Here is their web site:
http://www.hitachi-hap-la.com/Hi_Per...cer/index.html
here is a great price: http://www.carshopinc.com/product_in...d/27609/PSL100
Old Jul 22, 2008 | 07:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Buy the GM Denso Hitachi style one that came OE on late C4 Vettes. Good enough for the factory to install on Vettes.
Like this. $80
http://cgi.ebay.com/ebaymotors/NEW-S...spagenameZWDVW
I have a 18 year old one on my new 11:1 383 and it cranks it fine.
Old Jul 22, 2008 | 06:25 PM
scooter500's Avatar
Car: 87 Camaro Z-28
I ordered one - 18 years is extremely reliable and the overall price w/ shipping beats a Hitachi.
but gotta admit that Hitachi PSL100 looks awesome...
Old Jul 23, 2008 | 02:22 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You will enjoy lifting it with one hand while lying on your back under the car trying to get the bolts started compared to the big **** stock one.
Old Jul 23, 2008 | 08:15 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Alright! one thing they said no instructions, shims, or bolts are included. is there anything special to aligning this starter?
Old Jul 24, 2008 | 02:45 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You should alway check alignment of starter gear with ring gear on any starter install.
I have never had to shim but in some cases the starter is too close in and needs shimming out to get correct clearance.Too tight and startergear will lock on flexplate and not disengage.
Old Jul 28, 2008 | 08:48 PM
scooter500's Avatar
Car: 87 Camaro Z-28
the starter came in, brand new with factory test results all the way from... china. Anyway, it looks great and it is so light that before opening the box I was wondering if they actually put a starter in the box. it's hard for me to imagine an hitachi starter being smaller than this starter. :P
Old Jul 28, 2008 | 09:00 PM
LadyGreensleevz's Avatar
I'm new at this, so please excuse me if I'm in the wrong place. I need a vacuum diagram for a 82 camaro berlinetta. Please, someone help!
[quote=LadyGreensleevz;3838727]I'm new at this, so please excuse me if I'm in the wrong place. I need a vacuum diagram for a 82 camaro berlinetta. Please, someone help!
Last edited by LadyGreensleevz; Jul 28, 2008 at 09:01 PM. Reason: Automerged Doublepost
Old Jul 29, 2008 | 06:32 AM
Car: '82 Z28
Finally found a pic of my Hitachi starter installed. This is with a 168 tooth flexplate. Hope the one you got works out well
Old Jul 29, 2008 | 09:22 PM
scooter500's Avatar
Car: 87 Camaro Z-28
For carb car check out diagrams #58 or #67 at http://www.autozone.com/addVehicleId...00c1528005163f
Old Aug 18, 2008 | 08:53 PM
scooter500's Avatar
Car: 87 Camaro Z-28
this starter only has 1 large post and 1 small post where original style had 2 small & 1 large post. how should wires be connected to the new starter? Thanks -
Like this. $80
Old Sep 13, 2008 | 09:48 PM
scooter500's Avatar
Car: 87 Camaro Z-28
ok, mr slow here. finally got starter on. orginal bolts fit. used a whole pack of shims. temporarily moved a battery closer by a couple inches just so positive could reach posts on smaller starter. wiring was very simple as my 87 already was only using two starter posts (large one and "S" to the key). cranked fine original cable is 33.5 inches long & is too short by 2.5 inches. anyone got ideas on who has oem style positive battery cable at least 36" longer with 2 smaller wires, 1 to alternator and 1 to accessories?
thanks for tips and thank God the starter's on!
Old Sep 15, 2008 | 05:47 AM
scooter500's Avatar
Car: 87 Camaro Z-28
thought hey why not at look Corvette positive battery cables since that's this that starter I'm uising, but no lengths were listed on ACDelco or other sites. anyone know how long these cables are by ACDelco (for a 1990 Corvette)?
This picture sure looks right but no length mentioned:
ACDelco Part # 2SW56-3SY Application convertable
Other 1990 Corvette cables listed but without length:
ACDelco Part # 2SD56XE application 2-door looks like a generic
ACDelco Part # 2SX40-2 application ZR-1 no picture
ACDelco Part # 2SD40XH application ZR-1 no picture
Last edited by scooter500; Sep 15, 2008 at 05:49 AM. Reason: inserted a few words to make the post read better
Frozer!!!
Jan 19, 2024 04:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
milk
Aug 10, 2015 06:26 PM
