spark plg ????S
Old Jul 23, 2008 | 06:20 PM
tryn2gofast's Avatar
spark plg ????S
I have a 3 part question for you guys.
1. i need to run accel header plugs b/c of header clearance. which plug should i start out with?
2. If i start with that plug, is there any truth in dropping a heat range b/c of fuel blending. To get better fuel mileage.
3. In the future i want to spray up to 150.Ive talked to people at the track and they change plugs a step colder . Can you just keep the colder plugs in and get better mileage b/c of the 15%ethanol
Old Jul 23, 2008 | 10:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: spark plg ????S
Start with a stock heat plug. IIRC NGK FR series plugs are the same length as the Accels, and may be cheaper.
No
You can use the colder plug if you want, but you won't notice any difference in mileage unless you go too cold and the plug fouls.
Old Jul 23, 2008 | 10:20 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: spark plg ????S
Im running accel shorties in mine. You can go to any parts store and they should have a conversion list of what brand plugs convert to other brands.
If i can get a chance tom, ill tell you the number im running in mine.
I also read somewhere about running a step colder plug to get better gas mileage because of the 15% ethanol in gas now. Buy I cant tell you where i read it.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
