AC Clutch Bearing
Old Jul 24, 2008 | 10:24 PM
90-Vert's Avatar
Car: Looking
AC Clutch Bearing
I have a 1990 camaro it sound like the bearing is going out with the ac on. My question is: Is the bearing pressed into the pulley? I pulled it apart and it sure seams that way.
Old Jul 26, 2008 | 10:44 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: AC Clutch Bearing
You can't get it out without bending the thin part of the pulley that the coil faces. You should change the clutch assy or put a rebuilt compressor on it (what I would do).
Nothing worse than replacing a $80 clutch only to have the shaft seal on the compressor start leaking...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
