FUEL TANK VAPOR CHECK_VALVE!!! HELP!!!
Old Jul 27, 2008 | 05:05 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I'm not sure if this is the right thread, but here goes... I am having a little trouble finding a new vapor check valve for my cars. (MY 86 IROC and my 90 rs both need one!) This is the white plastic valve that clips to the drivers side frame rail above the axle. It has a vapor line (Rubber hose.) that goes to the fuel tank. Without it the car wont pass a fuel tank pressure test. (Required in AZ as part of the emissions test.) I have looked everywhere I can think of and have been told it is discontinued, (The chevy dealers.) Ihave been given dumb looks, (Checker, Autozone, Carquest,NAPA, etc.) I took my old one off and filled it with hot glue to get through emissions but this is a temporary fix.... Anybody know where I can find one? Part #?
Thank you!!
Old Jul 27, 2008 | 09:13 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: FUEL TANK VAPOR CHECK_VALVE!!! HELP!!!
Thank you!!
I think you're going to need to find a good used one. It shouldn't be hard as they were on most FI late 80's GM cars.
Old Jul 28, 2008 | 12:10 AM
I have 2 used ones from a junkyard. Both bad. The high heat, combined with the low humidity kills the seal inside them!! Just dries them out. There has to be a new replacement somewhere......Dosent there?
Old Jul 28, 2008 | 11:39 AM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
go to gmpartsdirect.com, part number10033125, this should be what your looking for
Old Jul 28, 2008 | 02:44 PM
I went to gmpartsdirect and tried the number. No picture!! I sent them a message asking for confirmation that this was in fact the vapor check valve, so we'll see... It seems to be almost triple the price of the old, discontinued part that my local gm dealers were telling me about. I dont care about the price, I just want the right part!! Thanks, kozman, I really appreciate it!! I will update you when I find out more!!
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
