Possible vats problem
Old Jul 27, 2008 | 11:50 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
My car will start but only run for 2-3 seconds.
This may be vats related.
I have tried different ecm's and different proms. Funny thing is I tried a prom from a '92 cavalier and it started and ran(albeit not very well, but it ran for 20 seconds)
I have plenty of fuel pressure, lots of fuel pressure and lots of spark. The injector pulse seems to get weak when the car is dying.
Is there a certain procedure to reprogram a VATS??
Old Jul 28, 2008 | 06:26 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: Possible vats problem
VATS only keeps the starter from turning over. What error codes does your ecm have? Have the chips been in dierect sunlight? Possibley a fuel delivery issue too... What is your fuel pressure? After all that you should have it narrowed down pretty good.
Old Jul 28, 2008 | 08:37 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
No error codes
I have lots of fuel pressure(checked at the rail and have a gauge in the car too)
I never thought of the direct sunlight thing, but I bought a brand new memcal from gm, so that ruled that out.
In the schematics, the vats takes fuel to the injectors and crank too.
Anyone know if there is a certain procedure to reset the vats?
Old Jul 28, 2008 | 01:59 PM
doc221978's Avatar
Car: '81 Z-28
There's a VATS bypass in the tech articles, and a lot of threads on it. You will have to pull off the driver's side kick panel to get to it. I wish i had schematics here. It would make things easier.
Here's a link for the VATS. It has everything you need to know about it.
https://www.thirdgen.org/vats
Old Jul 31, 2008 | 12:11 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
It wasnt a vats problem.
It was a grounded out throttle position sensor
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
