it still isnt running
Old Aug 1, 2008 | 07:36 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
so iv changed my plugs, wires, cap, rotor, fuel filter, battery,ignition switch and it still wont start
so heres whats happening ill turn the key and it will start for maybe 2sec. then die
check the video
http://www.youtube.com/watch?v=KDh-eUhr4bw
Old Aug 2, 2008 | 09:58 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Re: it still isnt running
Maybe fuel delivery related?
Old Aug 3, 2008 | 03:07 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
If I remember right, these engines have 2 oil pressure senders, I know the one for the gauge in the dash is on the drivers side of the distributor. The reason I mention this is that, if the ecm dosent "See" oil pressure rise then it will shut the fuel pump off. Find the sensor(Wherever it is.) and check the connection or replace it and I have a feeling you will have fixed the problem...
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
