Long block build
Old Aug 2, 2008 | 02:11 AM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Long block build
How long can an assembled long block sit covered in a bag for?
I bought a 383 LT1 and I am going to finish the last part of the valvetrain - rods, rockers arms and rocker stud girdles. How long can I let the engine sit like this if I install everything correctly - well lubricated with oil and the whole works? I have a lot of parts to still collect and dont want to worry about problems later from letting the engine sit for a few months. I bought it because it was a great deal and now I need to get everything else for the car - drivetrain and suspension.
The previous owner was a very knowledgable person who build most of the long block and had machining work professionally done. Anything I should check, and how can I check it?, before I trust that the engine is assembled right and to continue with the wiring and accessories? Crank rotates fine and smooth without binding of any kind.
Appreciate the help. This is my first engine build (i am really just finishing what was started...)
Old Aug 2, 2008 | 02:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Long block build
It can sit pretty much indefinitely. There's not a lot you can do to check it out without taking things apart.
Jake_92RS
Jan 28, 2020 10:37 PM
italiano67
Dec 11, 2016 09:21 AM
MoJoe
Sep 24, 2015 09:12 PM
Reborn756
Sep 4, 2015 03:42 AM
sreZ28
Aug 14, 2015 07:48 PM
