SA for alum heads?
SA for alum heads?
just trying to see what most people run with alum heads...i run afr 180cc heads....and was wondering what max SA would be and when should i have it all in at... my setup is forged bottom end...afr180cc heads 9-6-1 compression..edelbrock airgap rpm...tbi adapter and bbtbi...a/f is dead on 12.5 at wot and 13.5 mid accel and cruise is a 14.7 but i am just not sure if i have enough timing... i run about 36* wot.. have it al in by 3600... does this seem right or what? ...less? more? ..i get no knock... so jsut wanna a broad opioin...
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: SA for alum heads?
36 total should be right. You might bring it all in a little sooner depending on what camshaft you're running though.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
total looks ok, but its coming in awfully late - something in the 2600-3000 rpm range would be better for having all your timing in.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Mine starts to lose power at 38 degrees, so I run it right about 36. That goes for all setups I've had, n/a 10:1 comp. w/87 oct, 10:1 w/ 93 oct and 10psi, and 8.5:1 comp w/ 93 oct and 15psi. When I had a normal dist. I put a couple bolts in one of the crossbar pieces that move with the mechanical advance. This let me run a base timing of 20 degrees while still maxing out at 36 degrees, and I could run not-so-weak springs to keep the timing from bouncing all over the place at idle. I don't remember what rpm the timing was in by, but most people I've herd say to have it all in by 2500 or so.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
