Speedometer sensor
Old Aug 4, 2008 | 10:36 PM
jbucago's Avatar
Car: Black 1989 Formula Firebird
Engine: 5.0 TBI soon to be LT1
Transmission: 700r4 soon to be T56
Speedometer sensor
Application : 1988 Formula 5.7L Automatic 700R4
so when we had the rebuilt transmission put in it came with a different speedometer sensor. I know this because, the existing wire harness had a secondary harness piggy backed on the same harness to plug in the to speedometer sensor. ( there are 2 plugs with different plug both 2 wire contact.) we drove it for a while. speedo worked on and off.. a year goes by. i get a speedo sensor from the wrecking yard... plug it in, obviously one of the plug formations should work. and it did. pluged in.. turned the car to the on position and had a friend sit in the car while i spun the gear on the sensor . its working she says 10 20 mph.. great... i take the existing sensor out of the tranny and put the one i tested in the tranny and it doesnt work.
i tried putting the gear on the sensor i took out, because it was worn so it looked like.
the damn thing doesnt work still.
im frustraited.. i think im gonna go get a brand new speedo sensor and work from there!
Old Aug 6, 2008 | 07:58 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Speedometer sensor
Don't forget there's a plastic gear on the tail shaft of the transmission that likes to crack and slip on the shaft.
Take a look up in the hole while rotating the driveshaft slowly.
See "style B" in this picture.
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
TrevinE
Sep 14, 2015 03:20 PM
