TPI Intake
Old Aug 5, 2008 | 08:08 AM
marcus88's Avatar
Car: 87 GTA
Transmission: Automatics
TPI Intake
Are there any differences between the 85 TPI intake and an 89 TPI intake (bolt pattern for the heads)?
Old Aug 5, 2008 | 11:33 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI Intake
Yes, both the intake bolt pattern for the center four bolts is at a different angle, and the '89 intake doesnt have the hole for the cold-start injector. Only 85-86 manifolds are the same. You can also use any aftermarket TPI intake such as from Edelbrock.
Old Aug 5, 2008 | 03:02 PM
marcus88's Avatar
Car: 87 GTA
Re: TPI Intake
The reason I am asking is because I am looking into buying a engine from a guy that does not have center bolt heads but he was using the intake from an 85 TPI. Will I run into problems with putting my intake (89) on that engine or should I use his intake?
Old Aug 6, 2008 | 05:42 PM
Kevin91Z's Avatar
Re: TPI Intake
Yes, your intake has the four center bolts at a different angle than his 85 intake. Your intake will fit, but the four center bolts will not work. You could use his intake, or get an aftermarket TPI intake, as I said.
Old Aug 8, 2008 | 09:00 PM
THE87IROCZ's Avatar
Car: 1987 Z28 Camaro
Engine: 5.7 performance crate motor/TPI
Axle/Gears: Stock posi
Re: TPI Intake
You could just angle the holes on the manifold using a drill and carbide bit....I did it with mine and it set in there fine
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
