14101083 vs 14014416 heads
Old Aug 6, 2008 | 06:41 PM
2bfeard's Avatar
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
i was runnin the 416's heads on my camaro which has a 5.7 block, yesterday ive got a blown head gasket and i was going to rebuild my heads but found a set of 083's for 100 dollars ready to install. would those heads give me more power? would i be better off rebuilding the 416? 416's are 305 heads and have smaller chamber size.. my car has stock internals, just exhaust, 3.73, built tranny and a few other minor mods. thanks for the help
Old Aug 6, 2008 | 07:59 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: 14101083 vs 14014416 heads
Are your pistons dished? It seems that a 58cc combustion chamber and flattop pistons would cause really high compression and predetonation issues.
If you don't end up using the 083's let me know I've been looking for a set. In my opinion, the 083 would lower your compression, but would be a more reliable option. You probably would lose a little power unless your 416's have smaller intake valves, in which case it would be about a wash or just a slight loss in power.
what do you plan to do to the 416s when you rebuild?
Old Aug 7, 2008 | 01:02 AM
2bfeard's Avatar
Car: 1986 iroc
well bought the 083 and i think i would be installing these tomorrow, the other set i'l sell it. some one interested?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
