Deleting AIR, Shorter belt?
Old Aug 8, 2008 | 01:35 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
I will be deleting my AIR system this weekend. I have the routing for the AIR Pulley delete. What I need to know is which belt to go with? Anyone have the belt number? Thanks!
Old Aug 8, 2008 | 01:56 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Re: Deleting AIR, Shorter belt?
don't forget to try a search...took me two minutes to find
"I went with the Good Year Gatorback Poly-V belt. It's a 6 rib belt part numbers:
6PK2455
4060967 (I believe the 967 means the belt is 96.7" long)"
and in the tech articles it says 96.8
or you could do it the "fun" way and just use a string to measure it
Old Aug 8, 2008 | 08:40 PM
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Thanks for helping me out man! I would've searched but I was unsure on what to search for.
1992 Trans Am
May 10, 2023 07:19 PM
mike40sm2
Sep 1, 2015 02:15 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
