Wiper motor keeps blowing fuses?
Old Aug 9, 2008 | 03:34 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I went to turn my wiper motor on , they move to start then the fuse pops right away. Any ideas? I went all the way up to a 30a fuse and it blew that too.
Old Aug 9, 2008 | 06:03 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Wiper motor keeps blowing fuses?
you my friend have a short in the circuit, dont just throw higher resistance fuses in there chances are u could have burnt some wires cuz of that but anyways get a test light and check, better yet a multimeter, im not so good with electric stuff so i have someone else look at it seeing as how i wouldnt know where to start
Old Aug 9, 2008 | 11:15 PM
THE87IROCZ's Avatar
Car: 1987 Z28 Camaro
Engine: 5.7 performance crate motor/TPI
Axle/Gears: Stock posi
Sounds like you have a short to ground. Check all you wires from your switch to you motor. Also check to make sure nothing else runs on the circuit such as a washer fluid pump that may have damage to the harness as well. Make sure you don't have a wire that is damaged and may be rubbing up on some metal and grounding out.
Old Aug 10, 2008 | 01:35 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Old Aug 10, 2008 | 01:42 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I have a 4thgen dash so the ground could be the cause.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
