dam oil leak again
Old Aug 10, 2008 | 03:17 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
dam oil leak again
ok i replaced my valve cover gaskets with nice thick rubber w steel core, put new spreader bar bolts on, and tightned the oil pan. still got oil leaking. ive niticed that the bellhousing where inspection cover on the outside is soak as is the d.s exhaust tube... what would be leaking there> oil pan is tight and everything.....the oil filter bottom only has some oil, as does the oil pan like its got spray on it..... i dunno any suggestions?
Old Aug 10, 2008 | 05:25 PM
Engine: 355
Re: dam oil leak again
would the rear intake gasket cause oil to cover the inspection cover lil on starter and on the oil filter? i noticed a bit of oil on back of block, oil sending unit is tight.....
Old Aug 10, 2008 | 06:30 PM
Engine: 355
think i f ound my leak..............intake manifold. wiped block off and drove it and its soaked again wiped intake and papertowel got wet
Old Aug 11, 2008 | 01:46 PM
Engine: 355
whats best way to seal the intake from leaking?
Old Aug 11, 2008 | 01:52 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
some old fashioned work.
Go get a new gasket, or rtv if ya like (i only go with one mintue gasket by permatex) and replace it, there is no other way
have fun
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
