spark plug gap?
Old Aug 10, 2008 | 03:35 PM
87irocruns13's Avatar
Car: 87 Iroc, recently ran 13.733 @98.54
Engine: 350 HSR
spark plug gap?
I have an 87 iroc with a 350. I would like to know if I should change my spark plug gap when running a msd blaster coil and msd 8.5mm wires. I plan on running ngk v-power unless someone can talk me out of it. Thanks
Old Aug 11, 2008 | 09:09 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: spark plug gap?
I have run a msd blaster coil & 8.5 mm wires and left my gap at .035.
Old Aug 11, 2008 | 10:15 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: spark plug gap?
if you run an MSD box, you'll benefit more from a larger gap.
Old Aug 11, 2008 | 04:29 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: spark plug gap?
Go with AC Delco on your Camaro, Our camaros love their Ac Delco plugs,
Im using RJ45TS and .035 gap..
Maybe Ill try .045 intead, when i got msd dizzy and msd coil and wires.. maybe it will burn even better. !? who know..
Old Aug 11, 2008 | 04:50 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: spark plug gap?
i havent had any issues with delco, but perfer NGK. i would gap at .040 to .045. thats (.045) what i ran for a long time with no issues (before my HEI stuff).
Old Aug 11, 2008 | 04:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I know MSD recommends trying a larger gap with their box & coil, but I don't recall if they do for just their coil. Even so, their recommendation is a try & test process.
I ran the plugs in the 396 .010" over stock (NGK's), dropped it down to .005" over for the nitrous 100-shot (switched to AC's). Seemed to work well.
Old Aug 11, 2008 | 10:36 PM
Engine: 350 HSR
Re: spark plug gap?
Thanks everyone I appreciate the help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 03:05 PM
