Timing Cover Question
Old Aug 13, 2008 | 03:03 PM
FastPhoenix84's Avatar
Car: 1984 Trans Am
Engine: 305CID - Bored .40"
Transmission: TH700R4
I have a rebuilt 305, i have installed an aftermarket timing cover with the timing tab that bolts onto the side, i have also installed a new harmonic balancer that is from summit, but it is OEM and has the degree marks on it. I was told by a friend that i need the original timing cover with the timing tab on top to get the timing correct. Is this true, or am i ok with the setup i have, i have timed it with what i have right now and it is dead on. Thanks for any info...
Old Aug 13, 2008 | 03:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing Cover Question
The marks on the balancer need to match the timing pointer location.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
