strokin question
Old Aug 14, 2008 | 08:40 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
strokin question
when strokin a 350 would this crankshaft work and would i be able to use the same connecting rods or would i have to buy shorter ones http://store.summitracing.com/partde...6&autoview=sku
Old Aug 14, 2008 | 08:47 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: strokin question
that looks like a crank for a 400cid engine, and youd need longer connecting rods and smaller pistons not shorter ones
Old Aug 14, 2008 | 08:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That crank won't fit a 350 block as-is.
No, you don't need longer connecting rods. Standard-length 350 connecting rods are used with 383-specific pistons are most commonly used, or shorter 400 connecting rods and standard 350 pistons can be used. Other matching combinations of rods and pistons can be used as well.
Old Aug 14, 2008 | 11:47 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
would this crank work instead? http://store.summitracing.com/partde...0&autoview=sku it was under the 350 section not the 400
Old Aug 15, 2008 | 01:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It'll work if you've got a 2 piece RMS block, but you're probably paying $500 too much for it.
Old Aug 15, 2008 | 01:40 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
so whats a good crank and connecting rod combo that you guys would recommend. i have pistons already
Old Aug 15, 2008 | 01:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The rod choice will depend on which pistons you have.
What's the intended use of the engine?
Old Aug 16, 2008 | 12:11 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
well i kinda want something with good power but still streetable. i was talking with a friend after we pulled my 305 today and he says just leave as a 350 and get a 3.73 rear end. im thinkin about goin that route
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
