Engine clicks but won't turn over
Old Aug 14, 2008 | 11:30 PM
kbomb84rs's Avatar
I'll start with what happened first. To get the engine to turn over, the key would have to be slowly turned until the starter caught. If the key was turned at a normal rate, the engine would make one click as if starting to turn over but would stop. A few days later the starter went and no matter how slow I turned the key I had the same problem as if I turned the key at a normal speed. I changed the starter and had the same problem that I started with but at least the car would start. I then took the car off the road for major body work for a few months, and now I'm back to the same problem of the engine clicking once and not turning over. Do I have a bad ignition module or is it something else. Any thoughts would be appreciated.
Old Aug 14, 2008 | 11:52 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Engine clicks but won't turn over
what happens when you move the steering wheel up and down with the tilt
had the same problem long ago
it turns out it was the wiring inside the column
Old Aug 15, 2008 | 12:28 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
how is the voltage when it happens?
sometimes my cars do that when the battery is drained. a bad ground or battery connection could cause this.
Old Aug 15, 2008 | 12:58 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
when it does start does the car turn over slowly or normally you could have a voltage problem
Old Aug 18, 2008 | 01:45 PM
kbomb84rs's Avatar
The voltage appears to be good. I'll check the grounds, and give the steering wheel tilt a try for the wiring. As for when it did start, aside from not being able to turn the key all the way forward, the car would turn over well and would start fine.
Old Aug 21, 2008 | 05:02 PM
kbomb84rs's Avatar
Thanks to everyone for the help. I finally got it to start so I can at least get it home, but I am still having the problem with not being able to turn the key all the way.
B_Dubya
Aug 26, 2015 05:09 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BrianI
Aug 9, 2015 11:52 AM
