intake gasket problem... plz help!
Old Aug 16, 2008 | 12:10 AM
camaro_man's Avatar
Car: 92 Z28 camaro
Engine: 406 stroker
Transmission: built T350
Axle/Gears: 4.10's
ok to bring you all up to speed i got a 406 sb in a 92 camaro. went to move it out of the garage today and i found that my intake gasket had a burned hole in it on the pasenger side and another hole is about to burn through on the drivers side? i noticed it when i started it up and it sounded like i had a huge exhaust leak. any one know why my intake gasket would burn through or do i got to pull the top end off and figure it out on my own?
Old Aug 16, 2008 | 10:43 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: intake gasket problem... plz help!
Nope. You'll have to figure it out on your own. (just kidding!) It sounds like a mismatch between the heads and the intake. There is the "thing" about the angle of earlier intakes bolts in the center of the head where the exhaust crossover is. What heads and intake to you have?
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
