pcv wrong?
Old Aug 16, 2008 | 12:59 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
pcv wrong?
hey guys im back! I CHANGED my valve cover gasket, intake,dist, resealed oil sending unit, oil pan. and im still leaking oil. i was wonderong how a 350 pcv system is supposed to be hooked up. im thinking im gettin alot of pressure and its blowing out my gaskets. i hav an edelbrock performer intake and carb. i have the carb line in the front running to the driver side valve cover to a pcv valve, and the passenger with the chrome breather type. am i forgetting something?
Old Aug 16, 2008 | 10:22 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: pcv wrong?
Unless you have oil drooling out of the chrome breather, it isn't crankcase pressure. The pcv system sounds fine. The breather won't let it build any pressure.
I was hoping you meant to type "replaced" oil pressure sending unit.
The only thing to do is clean the the engine and put the car up on stands and run it to locate the leak.
And don't make Sofakingdom come in here and lecture you about the missing smog pump bolt.
Surely it's not that!....
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
NZKnight
Oct 15, 2015 02:47 PM
