LT1 Heads on a 1989 305
Car: 1989 Camaro Iroc Z28
Axle/Gears: Borg Warner 9-Bolt/ 2.77
I am planning on getting a vortech holley stealth ram. I need to get vortech style heads and I was looking at these.
http://cgi.ebay.com/ebaymotors/Edelb...spagenameZWD1V
Will these fit on my 305 motor with out any problems. Will the valves touch the cylinder walls? Will the cooling system work normally (LT1's are reverse flow)? how bout the EGR system? I would appreciated any help.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: LT1 Heads on a 1989 305
LT1 HEADS ARE FOR LT1S ONLY...Search...they will not work withought alot of machining to the coolant passages....just spend your money on some other heads....
Transmission: 4L80E/4L80E
http://store.summitracing.com/partde...5&autoview=sku
I was also looking at pro comp heads which use the vortec manifold. There are better heads on the market for vortec manifolds than non vortec.
I like the idea of using 54cc heads on a 305. If I put the 64cc heads on my motor as is, I will lose horsepower.
Last edited by 1989irocz1; Aug 18, 2008 at 07:53 PM. Reason: Automerged Doublepost
Car: 1991 Z28 1LE
Transmission: 4l60e
ok then find some small chamber small block chevy heads...but lt1 heads will need alot more machining then would a normal small chevy head set that u have milled down...
Same thing on a "standard" SBC head: http://store.summitracing.com/partde...5&autoview=sku
If you want 54cc heads, shave what you have/get down to that.
Making things more complicated than necessary usually ends up in wasted money and disappointment.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
