Loud "POP" in my car
Old Aug 20, 2008 | 08:58 PM
Joes1wood's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
I have an 85 Z28 with T-Tops. She's got 192 000 miles on her with an LG4 305 and a non WC T5.
When I put some pressure on the brakes and/ or make a sharp turn (in a parking lot, merge ramp, ect. Not beating on her) I hear several loud pops coming from the front right of the car.
I understand that the T Top cars are structurally weaker, but I do not know if the sound is flex or what not.
Please help!
Thanks,
Joey
Old Aug 20, 2008 | 09:08 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: Loud "POP" in my car
i am assume that the "pop" you are describing sounds like suspension parts shifting. if that is what it seems like and it is non-engine related (as you described), i would post something similar on the suspension board.
i would replace ball joints and related steering parts and/or bushings.
check the stickey at the top of the suspension board titled something along the lines of "Front end suspension spreadsheet."
Old Aug 20, 2008 | 11:07 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Check your stablizer bar end links. They are notorious for breaking then the two ends rub together and make alot of noise.
Old Aug 20, 2008 | 11:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check the top strut mount as well.
Old Aug 21, 2008 | 12:34 AM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
My car recently was doing that and it ended up being the tie rod..
Old Aug 21, 2008 | 02:11 AM
wjiroc86's Avatar
Car: 1989 RS
Engine: 305 tbi, junk, freakin slow!
Transmission: 700r4... holds up =]
torque arm bushing, my car was making a loud pop, then i put a new one in and fixed her up
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
