305 heads on 350?
Old Aug 21, 2008 | 08:49 AM
fbirdroller's Avatar
Car: 1986 camaro z28
Engine: vortec 5.7
305 heads on 350?
i have a stck 305 from an 86 z28 and i am wondering if it would be a good idea to port the heads off of it and put them on my 350 , basically in order to raise compression. my 350 is a stock 350 out of a 79 camaro z28. also is there anything else you can share with me about doing that, like the differences betweeen the heads and stuff
Old Aug 21, 2008 | 10:36 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: 305 heads on 350?
the exact casting numbers would be helpful. here is a good site for assistance with that: http://www.mortec.com/castnum.htm
Old Aug 21, 2008 | 11:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yep, it's a great idea.
You probably have 416 heads off your 86Z, and they would wake up the old 350 nicely - with some port work.
That's what i've done...
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
